holes
emtmike1971
i have a 14' sea nymph and i moved the rear bench forward about 1 foot(more room to steer) how should i fix the holes left in the sides(from drilled out rivets) and is it possible to but a flat floor (wood)in this v-bottom boat?
Whaler Proud
Re: holes
Welcome to the forum emt!<br /><br />As for the holes, some 3M 5200 should do the trick. You can get it at any marine supply store or WalMart.
Re: holes
Just Pop a Rivit into the Holes..........<br /><br />No Reason you Can't install a Floor.....
emtmike1971
Re: holes
if i put in a floor would/could their be a weight problem? is it possible to put in a standing platform in the bow?
Brian J
Re: holes
picked up some iron filling glue from a hardware store in the pipe section which comes in a cigar tube. Rub it together it gets hot and fill the hole. let dry sand and paint. Cabellas has some too can't remember the name. Will send you some if you need. I just restored my 14 foot and even used some below oars which takes stress no problems to date.
