Hoist points for 2006 Johnson 90 Salt water Edition
cornutts05
I'm trying to replace my steering cable and need to remove the engine from the transom. Not sure where to attach hoist. There are two threaded holes...one on each cylinder head. Are these to remove the head or can I hoist from here?
Joe Reeves
I'm not familiar with the 2006 design... BUT... for years dating back to day one of Evinrude/Johnson, the method used was always to attach a lifting ring to the three threaded holes that surround the flywheel nut. The underside of this particular lifting ring also has threads whereas it screws onto the crankshaft threads.
Honorary Supreme Mariner
Nope-----Lifting points / loops are cast into the block on the top.----Both sides.
boobie
That explains why a post of mine just disappeared. Thanks jbcurt00 !!!
V153
Personally I prefer lifting from the flywheel. That way the motor don't flip flop all over the place. Had my buddy Billy Bob the welder cobble this one up. Lifted several V4's and now a V6.
oldboat1
^^^have a similar one. I always use a safety chain as well, using factory lift ring or not.
