I finally installed a VHF and at speed it says High Voltage. I installed a new rectifier before the installation a few months back. The motor is a '79 140 seahorse. The volt meter on the dash reads about 16-18V I'm not sure if there is a regulator.
Hi Vic
Actually, the drop across a conventional diode is quite stable once you are over a few milliamps.
That is the same regulator which I mentioned earlier as being fitted to latter models with power tilt and trim.For your mtr OMC used to make an add on regulator kit part # 173640. May want to look into it.
What about something like this?
http://h2oinstruments.com/shop/index.php?main_page=product_info&cPath=20&products_id=127
Shouldn't think so.I believe so. Maybe it can be converted for this use.
