High rev power loss Evinrude OceanPro 175 HP
joweliedja
I have a 1995 Evinrude Ocean Pro 175 HP. At higher revs under load I have a miss/loss of power. Initially it felt as if it was a complete loss of all 6 cylinders for a split second. I have changed the power pack, which seemed to fix the sudden loss of all 6 cylinders. It still misses though and I am only reaching 5000 rpm rather than 5500 which I should be getting. 21 ft boat with 15x15 prop. From 3000 rpm to 4500 rpm it is missing. I have also changed the optical sensor and the stater plate. Spark plugs are new. I have elimited the main loom. I have elimited the the switch from the gear which changes the torque when changing into gear. I have elimited the slow idle switch. I have replaced all fuel lines and put in a new filter/water separator. I have disconnected one plug at a time while running the engine under load at higher revs to see if it is isolated to 1 cylinder. It doesn't feel like a fuel problem, though I have noticed a small fuel leaking from the part where the fuel line connects to the engine.(VRO Unit)<br />29 Dec Update: Thanks for the feedback. The 6 Cylinder miss is gone (powerpack) though I still have the miss at high revs. Cyl # 3 (middle on right back) is running hot. The spark plug (NGK Original and new)is a different colour to all. The head is OK and the top of the piston looks like it is getting hot. We increased the mixture so it would not run so lean, though it still looks like it is. Float level in the carby is OK, so now I suspect there is an air leak in one of the gaskets near the manifold. My mechanic has gone on vacation so I may have to wait. Any suggestions, tips? Thanks.
james roach
Re: High rev power loss Evinrude OceanPro 175 HP
When my 1987 200 HP did that it was the coils. They will probably fire OK while idling(mine did) but as you increase the RPM's they break down and you lose fire to the cylinder. If you find this to be the case, replace all 6. I hope this helps.<br />James
Solittle
I'm going with a guess on this one. I suspect that at higher rpm you are intermitently sucking a bit of air into the fuel line or you have some crud in the carbs.
clanton
Check for coil arcing to the metal plate that covers the power pack, if the coil is arcing, you will see the burnt spot on the plate. This engine also likes orignal sparkplugs, and sparkplug wires. The better pack came with a optical sensor. You could check the pack output to the coils while engine running under load at the rpms it mis fires. If you dont have peak reading meter, use meter set on AC scale all cylinders should be close to same reading. When it misfires you should see the meter dip.
seahorse5
What sparkplug brand, model, and gap are you using?
