high performance parts
licketdsplit756
i have a 1985 115hp johnson outboard. j115tlcos. threw this forum. i now have a engine that runs at all specs. i would like to take it one step farther now. and replace some stock parts with high performance parts.i use to race vw bugs. i got 250 hp out of dual port head beetle engine. what di i need to do to increase the powerfrom my boat engine.i relize boring the cylinders. how about jetting the carbs. maybe a hotter spark. hotter coils??.anyone that can help i would appreciate it.. ALWAYS HAD THAT NEED FOR SPEED the motor is on a ranger 1984 335v witch im in the process of totaly restoring it. gonna be a beauty when im done.
studlymandingo
Re: high performance parts
A jack plate with some setback is a good place to start; not an engine mod per-se, but a performance mod nonetheless.​
Silvertip
You would be money ahead in the long run to buy a bigger engine. You are dealing with a two-stroke engine and there are no after market parts. Fooling with an existing engine generally results in it burning more fuel for very little gain in performance. Work with setup and props. If rejetting the carbs gave a significant increase in performance the manufacturers would have done it for you. If you insists however, dig deep into your wallet and have the block ported, bored, new pistons, custom exhaust tuner, and then after you've blown a couple of motors getting things right, you will come to the realization that "I should have just bought a bigger motor".
Rancherlee
your engine is really only about a 100hp after the change from crank rated to prop rated HP in the late 80's. If yours doesn't have the "bubble back" exhaust cover then you could get one along with the carbs off a 140hp crossflow and pick up some HP. I believe the 140hp had larger ports in the cylinders though to help aid in the flow. Personally I would sell it and come up with a couple more bucks and pickup a 115/120 Looper V4 and you will notice a jump in power.
Frank Acampora
Or, if you really want to keep the engine, port it and if it is not bubble back, get one off another engine. Smooth, match, and radius all passages in the exhaust path. Install Boyeson reeds (may need to go one jet size larger) and you will be surprised at the jump in performance. Had a friend in a Bass club do it on a 90 hp. V4 looper and the engine is HOT. He is swinging the highest pitch prop available( I forget--21 or 23 ), vented to the max for reasonable idle and he still turns 6,000 RPM. Takes a lot of time though-- easier to buy a bigger engine.
kenmyfam
Bigger motor seems the logical option.
Bob_VT
Many people have tried (been there done that) and when you add up all the time and parts the return is not worth it. Shop for a bigger motor no question about it.
hitace -you can get a outboard Nitrous Oxide Systems form here.they say 40% more power for a few seconds with a push of a button
Not good advice........You need to look at that link. Those set ups are for jet-ski engines and would probably grenade an outboard.
licketdsplit756
sound advice bigger motor it is ty now i got to figure out what else can i tare apart to keep me occupied.:p
hitace
that was the right link just click the first one and then click catalog page and scroll down to where it says two stroke outboard nos is available for more info call so and so
Barnacle_Bill
If you really want to beef it up check with the boys at screamandfly.com. Thats what they do for racing them.
deejaycee_2000
Forget about trying to make that motor a racing engine, rather buy a stock standard mercery racing motor, it's all you need ....
hitace
i read mercery cant make there racing outboards no more do to emission laws
hitace
th EPA seems to be knocking them off one by one.pretty soon were just going to have big globs of steal that weigh 7898789890 and do 1 mph but make no smog.it seems everything in the world is getting smaller lighter and more compact accept outboard.there doing the complete opposite
rndn
I wish the EPA would really look at the total contribution from outboards instead of saying they polute. Most outboards are used to take people to a fishing hole and then shut off and the electric trolling motors take over. People don't run and outboard for thousands of hours like autos yet we are being subjected to the same criteria.
