High Output alternator
Kamilo
Re: High Output alternator
Next question, do you actually have 10 speakers hooked up to the top 2 amps?
I have two 8" 8ohm jbl loudspeakers hooked up to m4500 at 8ohm.
Two 7" 8ohm neodymium loudspeakers to m6450 and two tweeters to the last two channels
Kamilo
I have en equalizer and can set up range on amplifiers but should i also get a midrange crossover and install it on midrange 8" and 7" loudspeakers box or just get better preamp crossover?
midcarolina
@ 8 ohms you are cutting the power to speakers almost in half......
midcarolina
I would think the hi pass and low pass filters and freq. settings would be all you need.........
bruceb58
Depending on your volume, I really doubt you are drawing much over 10A. I would live with your current alternator.
Kamilo
Yes it is hooked up with battery isolator and it doesn't really charge my batteries well. I need some more juice in there. Dancing girls dont like when music dies little by little ;)
sam am I
I was staying out but, THIS is getting too serious now!! Sooooo, really what you're saying is these dancing girls are not pleased?
Kamilo
They are, but just until the sub goes down first and they want to keep dancing.
bruceb58
How many batteries are in your boat including your starting battery?
sam am I
Hmmmmmmmm, well this is more serious then it appeared man! If it were me and my dancing girls were not happy. I would.........well, that's beside the point but.........
For just standby power(engine off), perhaps add another battery if needed and in any case, optimize my/any charging methods, two thoughts or so here.
Loose the "one wire" idea's/setups.....go only w 3 wire(remote sense type) and use only the type of batt. charge management devices(ACR's, VSR's, ISO's etc) that drop say less than or equal to 0.1 volts for example when charging. Doing both will help you charge what batts you have as fast as possible with your given alt when engine/alt is up at rated speed for rated amps.
If run time current of say 100/150/200 amps, whatever (I'm not going to read this whole thread to figure it out, just an "IF") at idle'ish was required for quicker recharge and/or real time current needs......I'd consider a re-pully kit to spin the alt faster (not too fast though, there are always certainly trade-offs involved, say 3 to 1 ratio perhaps, not sure, I'd have to look at spec's) and/or simply just low RPM, high amp alt's.
Google this stuff, tons of info on how to do this.......Dancing girls and power issues have been around for eons
bruceb58
Are the 2 for sound wired in parallel or do you switch between them?
Kamilo
Thank you, do you have any sugesions what alternator should i get? This is what i have now.image.jpgimage.jpg
bruceb58
Then you only need 1 ACR wired between the starting and set of parallel batteries. If you stick with the isolator, you should remote sense on the stereo batteries.
Kamilo
I will get the ACR
bruceb58
Do the ACR before you go out and get the alternator. Maybe it's all you need.
