High oil pressure 4.3
BBeall
I have a 1998 larson sei 186 with a 4.3 volvo penta that has 170 hours on it. I was recently out on the lake and my impeller blew up, I wasn't paying attention and got the motor hot (around 200 degrees according to the gauge) i shut it off but it started dieseling and eventually died. After getting the boat towed in and back home i started the work... replaced impeller, flushed cooling system, replaced exhaust flappers, and did an oil change using 25-40 as recommended by a local marine mech. The boat started fine with no new noises but my oil pressure was much higher than normal according to my oil pressure gauge on the dash. i normally run about 35 when at idle (700 rpm) this time it was 60 psi, so i replaced the sending unit and now i run 40 psi at 700rpm and climb all the way up to 75ish at 2500 rpm.
What could be causing the high oil pressure? I have not hooked up a manual tester yet.
Ayuh,.... Sounds like what fresh, cold oil does,....
Once up to temp, pressure should normalize,....
BBeall
I got it up to temp but it still ran about 50 psi and all the way up to 70ish at 2000rpm the books call for sae 30 but the mech told me 25 40 so thats what I got
Your oil pressure is fine.... Go boating
