hi speed jets
5150abf
Re: hi speed jets
Could be wrong but generally they are inside the drain plug on the float bowl.
Pull the drain plug and you can see them, you will need a long skinny screw driver to get them out.
As a hint, keep the cover screws with the jets they cover so you don't mix them up.
