Hey radio heads and sparkys.....have a VHF coax question
replacing the new antenna on the boat because I forgot it was up and in a bridge vs fiberglass antenna situation....... guess what losst
anyway, new antenna showed up.
I can either spend 3 hours cutting out 3M 4200 to pull new wire, or I can add a connector at the folding wake-tower hinge.
If I put a connector there, how much signal loss will I see?
sam am I
TMI.............and in terms of power
10*log (Po/Pi) = db
Assuming -0.5 db loss per connector (think its actually less, something like -0.1 db, almost neglectable, connector quality dependent I'm sure)
At any rate..........
10* log (x) = -0.5 db
solve for x
log (x) = -0.5/10
x = 10^(-0.5/10)
x = 0.891
The ratio of Po (power out) over Pi (power in) = 0.891
Meaning?
If Po/Pi = 0.8912
And if we assume Pi = 15 watts for an example
then Po/15 = 0.8912
or Po = 15*0.8912
Po = 13.37 watts
If you're sending in 15 watts, you're going to lose 1.631 watts (-0.5 db) at the connection and have 13.37 watts left to transmit.(assumes no cable loss).
Just a guess though.......
Makes more sense to dig out the 4200 and run the whole thing..... Thanks guys
