HESITATION
THWildwood
WHEN I THROTTLE UP THE ENGINE STALLS OR HESITATES I HAVE A 120 4CYL 1981 MERCRUISER. I'VE REPLACED ALL THE ELECTRICAL PARTS. I THINK IT HAS A CARBURETOR PROBLEM?
Trent
Re: HESITATION
Check that timing is correct. If it still does it install a carb kit with a new accelarator pump.
loriaw1
Re: HESITATION
Is this only under a load w/ the outboard engaged? Are you able to rev engine w/o it engaged?
elpaso
Re: HESITATION
With engine not running. Look down the throat of the carburetor.<br />Have someone pump the throttle, you should see a spurt of fuel<br />with each pump. If not the accelerator pump is not working.<br />Rebuild as Trent said.
Re: HESITATION
I THINK IT HAS A CARBURETOR PROBLEM? <br />
Ayuh,.......... I Think You're Right,.... No Doubt a Fuel Delivery Issue.............<br /><br />Just Which "ELECTRICAL PARTS" did you replace,???<br /><br />You'll also make alot more friends here at iboats if you Loose the Cap-Lock............ ;)
QC
Re: HESITATION
For what it is worth, I had a '84 140 OMC (3.0 liter vs. your 2.5 liter, but based on the same GM engine). From the day it was new it would hesitate if I hammered the throttle instead of feathering. The ONLY thing that worked for me was 1-2 bottles of cheap fuel treatment in every tank. Didn't matter what it was; lead replacemnet, STP fuel treatment etc. etc. If I used it I could slam the throttle for pulling skiers etc., if I didn't it would burp . . . Very unscientific, no real explanation, it just plain worked.<br /><br />BTW, I am an idiot when it comes to carburetors, so it is a good thing this helped. :D
Re: HESITATION
Here, THWildwood,.........<br />I'll Bump this 1 Right Up to the Top with Your Other Thread.........<br /><br />These Forums Work Best with 2 Way Comuication.......<br />These Answers Won't Help You,... If You Don't Read Them.............<br /><br />And,...... Loose the Cap-Lock........
