Hesitation on a 2002 Yamaha F115
rjpjr924
I have a 2002 F115 (four stroke fuel injection) that when it is throttle up it has a hesitation, it runs fine from mid to full range.
Cleaned the entire fuel system including the VST tank.
Fuel pressure with key on not running is 44-45
Fuel pressure at an idle is 37-38, but when I throttle it up the pressure increases to 45 miss fires then stalls.
Any ideas?
rjpjr924
Re: Hesitation on a 2002 Yamaha F115
No alarms and do you mean a leak down test?
JUSTINTIME
no cylinder drop, to test if the spark is there and the injectors are working
rjpjr924
How do i perform a cylinder drop?
