Re: Hesitation during Hole Shot
If the motor runs fine at WOT throttle, and pumping primer bulb has no affect, then the next step would be to check the carbs. Possible sticky needle valve. Might get lucky and be able to get away with just taking fuel bowl off and seeing if any debris has accumulated in the bowl. Be careful not to bump the float too hard and throw off the float setting or damage the needle valve. Take your finger and gently move the float up and then down. The silver needle valve should drop down as the float drops down. If it has a tendency to stick, then I would replace needle valves in both carbs.
If you don't already have one, an inline filter between the pump and carbs is a good idea. If you do have one, check to see that it's not plugged up.
