Manipulator
Thread starter- Joined
- Apr 11, 2005
- 743
Get this, last weekend I go to check the oil on my boat. It has the OMC system with the rams that raise and lower the engine to trim the boat. So I typical put my trusty little metal (aluminum) level on the side of the valve cover (where the intake manifold and valve cover meet), bring the trim up or down until the engine is level and check it. I check it and all is well. We take off and the boat is running fine. I go and get gas and as I take off all the sudden I hear a "pop" from the engine cover and my RPM is dancing all over the place. Engine keeps cutting out. I think, "wow I must have some bad gas". But there is no way it could have got to the carb that fast. I nurse it back to the marina at idle, won't hardly run past idle. It's cutting out, and backfiring through the carb. I don't know what to think other than another ruined 4th of July weekend. I get back and take the engine cover off and look and see nothing. It's got to be the timing. I take a closer look and stupid me left the level on the engine! When I put the trim down (engine goes up in front) to plane the boat the level slide to the back of the engine and was hitting the terminal off the coil shorting it out. Doh!
