This is my second season winterizing my 3.0L mercruiser engine and probably my second season making the same dumb mistake! When you remove the drain plug from the engine block make sure to have some type of "deflector" for the HOT stream of water that is going to shoot out. A small flat piece of plastic works well to direct the water to the bilge and not on the boat floor. You will be surprised how much HOT water is in there. I am a little obsessive about keeping the inside of my boat dry and managed to soak the rear port side in a heartbeat. <br /><br />Jeff
