here it is
capt-stuck
remember when i told you my motor putted out? well i finally got 10 min so i went out and took some pics for you to see, and maybe we can all put our heads together and figure out what went wrong. my boat
rodbolt
Re: here it is
judging from the darkened paint and the topplug photo you really need to test tyhe compression before going any futher.<br /> do you know how to run a compression test ?
capt-stuck
Re: here it is
not really. Don't i hook the gauge up tp the spark plug hole and crank the motor?<br /><br />Before this it did have good compression. it was 125,120,125 top to bottom.
D
DJ
Guest
Re: here it is
Yes, that's about it. Just make sure the throttle plates are open. Wide open throttle.
rodbolt
Re: here it is
hello<br /> well ya only have to over heat it once, sometimes there is no second chance. the throttle bores on a two stroke dont have to be wide open however I would prefer they were. screw in your tester,available at wally world for 20 bucks or so, and have some one crank the engine over while watching the gauge. note how fast it climbs and the pressure it goes to. should be about equal on all 3. the max pressure should be within 10 pounds. ground all the spark plug leads or pull the kill lanyard before testing. dont want pesky sparks flying everywhere. a story behind that one day :) .<br /> do this for all three cyl with all plugs out.
capt-stuck
Re: here it is
O.k the comrpession are as follows; 110 on top, 35 middle, 95 bottom. so blown head maybe?
novicetech
Re: here it is
Maybe, you need to remove the head next, if gasket is blown you will be able to tell. You also need to check the impeller and t stat to make sure you have plenty of water flow. when you remove the head you will also be able to see any damage to the clyinder walls. You should be able to turn flywheel rather easy by hand with head removed. Be carefull when removing the head bolts,maybe loosen a quarter turn, then tighten an eigtht of turn until, this will free up any corrosion that may be on the bolt threads.
eurolarva
Re: here it is
Can you post your model number. Looks like early 70s model. As mentioned before those bolts could be corroded and easy to break. Go to walmart and get some pb blaster and soak the screws as best you can. If you break one they are a bear to get out. Also a heat gun for removing paint might help getting them out. You will also need a good service manual. Hopefully it is just the head gasket. If the pistons are shot you may want to consider parting it out.
capt-stuck
Re: here it is
Euro the motor is supposed to be a 1985. i never checked the numbers or anything yet, if i can even find them. I hope that this motor can be fixed, because new motors are expensive, and if i have to buy a new motor I should just get a new boat. That is not an option for me right now.
rodbolt
Re: here it is
hello<br /> its hard for me to see the cylinder walls but the piston crowns appear intact. oil the walls looks like a touch of rust is forming.<br /> if the walls are not scared have the head surfaced and replace the gasket. the best surfacing machine is a 6 or 8" belt sander. you can use sandpper and 120 grit on plate glass but its a several hour ordeal.the head is warped. no need to check it just have it flattened, in my area the guy charges 15 dollars to do it unless its so warped he has to mill it. use perfect seal on the new head gasket. now ya have to find the cause of the overheat. its either t-stat water pump or pressure control valve. replace/repair all three.
capt-stuck
Re: here it is
How do you know the head is warped? what profession is the person who does the shave down? and i do not think the boat has a warning buzzer. the wiring was so f----d up on it when i got it. so if there was one there i didn't see or hear it. The gasket looked brand new like, but the t-stat from what i saw through the head did look coroded. The screws for the t-stat housing are froze. i heated it a little, but still nothing. i dont want to break the screws, or the housing, so i sprayed it with wd40, and hope it works.
rodbolt
Re: here it is
oil most likely wont help. heat is the key. <br /> how do I know the head is warped? cause ya overheated the **** out of it and 30 years of wrenching on them. thats mostly how :) :) .<br /> any way you have to make sure the head has less than .002" warpage fom end to end. chysler/force liked to pop head gaskets anyway. do you have a little black thing on the top of the block or in the head that has an orange wire to it? if so that is the heat switch. test it while its out. your going to have to have a service manual. not much other way around it. it will say use silly cone sealent. DONT. use perfect seal. the blackened paint on the head indicates it was hot. heat will warp the head and allow water in the cyl and gas out,hence a loss of compression.<br /> a blown head gasket is a result of a cooling system failure, ya have to correct the cooling system or it will do it again,if the cylinders are not damaged this time they may be next time. use a hand impact and oxy/acetylene on the t-stat screws. propane usually is not hot enough. if they braek its not hard to drill them and rethread the hole. not for me anyay:) I do 4 or 5 a week.
capt-stuck
Re: here it is
Hello, <br /> Rodbolt where is the pressure control valve. I cant find it in th manual
bioman
Re: here it is
Hey Roadbolt, when a headgasket goes (on an 86 Force 50 HP), is there still enough compression to run (compression 125?). My engine runs (poorly), compression is 140 top/125 bottom, with mysterious oily guck accumulating in the back bottom of the engine cover....I REALLY don't want to do a rebuild yet...does this sound like blown Head gasket?<br /><br />Thanks!
