Re: here it is
Maybe, you need to remove the head next, if gasket is blown you will be able to tell. You also need to check the impeller and t stat to make sure you have plenty of water flow. when you remove the head you will also be able to see any damage to the clyinder walls. You should be able to turn flywheel rather easy by hand with head removed. Be carefull when removing the head bolts,maybe loosen a quarter turn, then tighten an eigtht of turn until, this will free up any corrosion that may be on the bolt threads.
