Help
Wrongway1516
I have a 1979 morcruser 120 the boat cout on fire under the dash so I am rewiring it have to cut wires to get it out so now I need to wire it for the rear plug to the dash and the ing. Switch but can not fine the wiring diagram to go with an someone help thanks I am over the road drive so I may not check post all th time:confused:
CptAJ
Re: Help
You might have to buy the repair manual to get that wiring diagram. It should be around $20. I don't know where to find those manuals for free online (wish I did =( ) although maybe someone in here could post a scan or picture of the proper page.
Wrongway1516
Re: Help
I will have to look again the book was not much help last time.the wires in the boat are differ then the ones I have the fuses sucks
Don S
Re: Help
That link will only get you engine and engine instrument wiring, NOT the wiring for all your other accessories like bilge pump, blower, nav lights, etc.
Wrongway1516
Re: Help
Don for some reason it will not come up.is there somewhere I can look for the wiring at
