help!
mcfarlinbennett
I was just given a boat with a v6 evinrude motor model 200649s not sure of the year..90's? the prop shaft is bent, I got the propeller out but cant get the shaft off. Any suggestions?
a70eliminator
Re: help!
You said that bakcwards, got the prop off but can't get shaft out is what you mean right, right.
I'm not sure but think you have to remove the shifter fork before you can get the gears out.
a70eliminator
Re: help!
I'm not sure but think you have to remove the shifter fork before you can get the gears out. Have you removed the big snap ring yet?
Randybeall
Re: help!
Ok, you have removed the nut and taken the prop off. What else have you done? You must remove the gearcase from the power head to proceed from here. Do you have a manual? I would suggest you not do anything else until you have one. Follow the steps for gearcase removal and then disassembly. It is work but not extremely complex.
tx1961whaler
Re: help!
Which shaft? Assuming that you're trying to remove the lower end, are you talking about the shift rod or the drive shaft?
