HELP
88spl
Hi this is 88spl's daughter Brooke! And in my science class we are to do a report on anything related to science. Well what im wanting to do my report on is the Black Mamba snake! If you happen to know anything about this snake or any websites that i can find information about this snake please let me know! <br /><br />~thanx~
sloopy
Re: HELP
hmn.. Your watching to much Kill Bill.<br /><br />I thought your dad got mag last time you asked iboats for help!<br /><br />THe only thing I know about the black Mamba is that it is the only snake that will bight you for the hell of it.
88spl
Re: HELP
haha yeah i did kinda get in trouble last time but... he told me this time to get on here and ask
ob
Re: HELP
Just type in the search words 'black mamba' on aol.Lots of reading.
88spl
Re: HELP
i'll try that. do you have to have aol?
ob
Re: HELP
It helps.I'm not familiar with MSN if that's what you have.
88spl
Re: HELP
i have netscape and internet explorer
88spl
Re: HELP
lol ok, really he did i promise!!!
sloopy
Re: HELP
ok, if he did; have him come here and tell us :D !!! J/K<br />good luck on your assignment.<br /><br />I will stop bugging you now...
Bassy
Re: HELP
If you want info. put Black Mamba in the search at Google.com. That should give you plenty of sites to research. Coming from a teacher, which I am, I think you need to research for yourself. If you get any help from this site I hope you give credit as a cited source. <br />Good luck with the assignment.<br />Bassy
SpinnerBait_Nut
Re: HELP
The black Mamba is Africa's deadlest snake known.<br />Jaws: The lower jaw can be temporarily dislocated to the snake to swallow prey that is much larger than its own head.<br /><br />Posture: Even when moving at speed the black mamba can hold its head about 50cm off the ground.<br /><br />Speed: Over long distances it travels at about 11km/h in short bursts.<br /><br />Colouration: Grey-brown upper parts, with paler grey underbelly.<br /><br />Striking Position: The black mamba is long and powerful, and can lift the front part of its body up to 1m from the ground when striking.<br /><br />The Green Mamba: Smaller, shyer and less poisonous than the black mamba. Lives in eastern and southern Africa.<br /><br />The black mamba requires frequent food as it is active and moves at high speeds. <br /><br />It hunts rodents, birds, lizards, bats and other small mammals. <br /><br />It strikes accurately and at lightning speed with its fangs.<br /><br />It has extremely keen eyesight and can lift its head and the front of its body about 1m off the ground when striking.<br /><br />It injects lethal venom through two hollow fangs at the front of its mouth. <br /><br />The venom attacks the nervous system and rapidly suffocates the victim. <br /><br />Enzymes in the snake's saliva and venom start to digest the prey even before it reaches the stomach.<br /><br />The black mamba's high rate of digestion ensures that most prey is completely digested within a few hours.<br /><br />* The black mamba is the fastest snake in the world, reaching speeds of 23km/h over short distances. <br /><br />* The black mamba can digest an animal the size of a large rat within nine hours.<br /><br />* Snakes such as the black mamba are dark-skinned to enable their bodies to absorb a lot of radiant heat. Desert dwelling snakes are often paler to reflect heat, preventing overheating.<br /><br />* The venom of both the black and green mamba is 'milked' from the fangs and used in medical research.<br /><br />Now what else you need to know?
Bob in Calif.
Re: HELP
Hi Brooke.........<br /><br />Go to this site, it will give you some short, precise information about the Black Mamba.<br /><br />www.blueplanetbiomes.org/black_mamba.htm <br /><br />PS: Calipornia is loaded with multi-colored Mamba's. But here they are called, "Politician's."<br /><br /><br />...Bob in Calif...
