Charlie A. R.
- Nov 26, 2005
- 2
I just bougt a 1996 Wellcraft with a 1995 112 Evinrude Special. Problem is motor runs great at WOT till you slow down after first starting. Then it will only run at about 1/4 speed till you stop and let it sit awhile. Never misses just seems not to be getting enough fire or something. I changed the fuel filter and checked all the wiring. Changed the plugs. Can't seem to find the problem. The last owner had it go dead on him while out oneday and replace the stator and retifier. Also tach has strange reading when the motor is in the slow down phase which it still runs good but will only make 8 knots. When at full speed it runs at 28 knots till you slow down and then will only go 8 untill you stop and let it sit awhile. Please help if you can.<br />Charlie
