Re: Help with Wiring Diagram
Don' know if this'll help or not.<br /><br /> <br /><br />Black---------------------------------All Grounds <br />--------------------------------------------------------------------------------<br />Black with Yellow stripe---------Magneto/short to Kill <br />--------------------------------------------------------------------------------<br />Gray----------------------------------Tachometer signal <br />--------------------------------------------------------------------------------<br />Yellow with Black stripe---------Choke <br />--------------------------------------------------------------------------------<br />Red----------------------------------Unprotected(12V+)from battery <br />--------------------------------------------------------------------------------<br />Red with Purple stripe-----------Protected(+12V)from battery <br />--------------------------------------------------------------------------------<br />Purple-----------------------------(+12V)from ignition switch <br />--------------------------------------------------------------------------------<br />Tan------------------------------Overheat sensor to warning horn <br />--------------------------------------------------------------------------------<br />Pink-------------------------------Sending unit to fuel guage <br />--------------------------------------------------------------------------------<br />Yellow with Red stripe----Ignition switch to starter solenoid <br />--------------------------------------------------------------------------------<br />Yellow-----------------------------charging stator to rectifier <br />--------------------------------------------------------------------------------<br />Lt.Blue with White stripe--------Trim up <br />--------------------------------------------------------------------------------<br />Green with White stripe-----------Trim down <br /><br /><br />--------------------------------------------------------------------------------<br />Some more standard wire colors used on many inboard boats, always double check though, as some vary or may have been changed along the way! <br />Some standard colors for boats since 1980 are as follows: <br />· heavy red 10 guage (main battery) <br />· heavy black (main ground) <br />· purple (ignition) <br />· yellow (starter solonoid) <br />· grey (tachometer) <br />· brown (temperature) <br />· blue (oil pressure) <br />· brown with stripe (alarm) <br />Accesories <br />· pink (fuel sending unit) <br />· yellow (blower) <br />· brown (bilge pump) <br />· grey (navigation lights) <br />· heavy green (bonding wire) <br />· red (misc electrical ad ons , vhf , depth finder, stereo, radar, power supplies) <br /><br /><br />c/6<br />Hooty
