Help with Temporary lighting set up
samm835
I have just replaced all the carpet in my pontoon, and I took everything off so it could be done right. In the process I noticed my front lights(green/red) and my rear light(white) that the wiring had some dry rotting. I am wanting to replace all the wiring and then hook back into the fuse box, but I want to take the boat out tonight for a night ride with my wife. The wire is already layed out and runs from front to back, just for tonight can I hook these straight to my battery so we can go out tonight, and then this weekend they can be ran correctly to the fuse box? I hate to do damage to the lights or anything electrical, but it is a temp fix not stationary. Thanks in advance.
lncoop
Re: Help with Temporary lighting set up
Absolutely. You could also make a crude switch cheaply by splicing in male/female spade connectors, then you could simply "plug and unplug."
seabob4
There are those here and elsewhere that will STRONGLY recommend not doing that. I say go for it, just don't drop a wrench across your battery terminals...
samm835
Thanks for the help....gives me a little bit more confidence, like I said its not permanent....just something for the time being to get me on the lake tonight and maybe tomorrow. Thanks,
