Help with starting problem and Year of Johnson Tracker 40HP
Britcom61
Hi all, I am new to this forum and am in need of some help.
I own a Bass Tracker with a Johnson 40Hp outboard. The motor was running fine last year. I went to the lake today and could not get the motor to start at all. I checked for spark and there is none. Any help troubleshooting this problem would be greatly appreciated. I do not know the year and was looking for some help with that also. Model #TJ40ELETB and Serial #G03266535.
Thanks in advance for your help, Lee.
rickdb1boat
Re: Help with starting problem and Year of Johnson Tracker 40HP
Hi Lee. The first thing to check is the kill switch. Make sure the lanyard is connected. If this fails, disconnect the large red plug in the engine compartment and jump out the starter. See if you then have spark..It's a 1993 model...
Britcom61
Yes the motor has a kill lanyard and the lanyard is attached. Thanks for the help, I will go and check the link you posted, all the best, Lee.
Xcusme
Welcome to iboats,
You have a 1993 motor. Have you checked the 'man overboard lanyard" (kill switch)??
edit:
Boy , talk about a day late and a dollar short...I have to learn to type faster !!!
Britcom61
Hey Rick, what exactly do you mean "jump out the starter"? Lee.
