help with starter
js361
hey all.....my starter is not spinning the flywheel....i have a 90hp '95 johnson....a buddy suggests i hit it with a wrench while someone tries to start it....is this bad advice?
o/b tech
Re: help with starter
If you hit it to hard you will seperate the magnets inside from the housing. You can tap it but not recommended. How is the state of charge of the battery. A weak battery will also do the same thing. Hope the info helps.
js361
the battery is fully charged....so u say give it a light tapping?
Is the starter spinning at all or does nothing happen when you turn the key? If it is spinning but the flywheel is not turning, see if you can turn the bendix counter clockwise to see if it rises up to mesh with the flywheel teeth. Sometimes they stick. You also said the battery is fully charged. That does not mean its a good battery. Use a known good battery -- like the one from your car to prove the battery is not the problem.
JB
NO!!.<br /><br />Go to Engine FAQ and troubleshoot it in the "Outboard wont start" article.<br /><br />Let us know what you find, and good luck. :)
js361
problem solved! i overlubed the bendix....cleaned it yup & she turned right over! Hope no damage is done from hittin' the starter! LOL
