mnwolftrack
Thread starter- Joined
- Aug 15, 2009
- 16
Hello, I recently just bought a 9.9HP 1990 4 Stroke long shaft high thrust Yamaha kicker, model FT9.9ERLD. This is my first post and it's somewhat long, but I'm trying to include all info upfront for a faster resolution.
Anyway, not knowing a ton about these motors, I took the seller's word that the motor only needed some throttle/shift cable ends to finish hooking up the 2004 model tiller handle he bought and installed to convert from it's original use as a remote kicker type motor to a "regular tiller." Well, needless to say, the seller seems to have left out some important info, or didn't know what he was talking about. I have no way to actually START the motor.
Anyway, here's what I have to work with. The motor above, plus a 2004 style tiller handle with built in throttle, kill switch, and gear selector on it and cables.
I also have Quicksilver 3000 Classic remote control, Morse cables, and a generic used ignition switch. These were not previously installed with this motor but were included for me to try to figure out how to set up should I decide to use the controls. In the long run, I was considering installing the remote control once I decided if I liked the motor enough to keep it. For now, I just wanted basic tiller operation without the fuss of installing the remote control. I have all the mechanical parts I would need to use the controls, but i would still be missing some sort of wiring harness to connect to the 7 pin harness coming out the front of the motor.
Here's where I'm at:
I'm trying to finish the conversion to a "regular tiller." I have the tiller cables hooked up with the proper cable adapters, the proper housing adapter, etc.... My main issue is wiring. There is no way to start the motor because there's no start button. In a moment of stupidity, I figured I'd just be able to use the emergency rope for now to at least get the motor running the old fashioned way. But, that obviously doesn't work. I need the ignition switch, or some sort of start button to make this thing fire up.
The motor has a 7 pin connector coming out the front of it. I'm assuming these are for the ignition switch controls. I cannot find wiring diagram info on what the wires mean, but despite 7 pins, there are only six wires actually coming out of it inside the motor and going to a row of retainer clips to hold bullet connector fittings in place:
Red
Yellow with red tracer
Black
Green
White
Brown
What do I need to hook up to this 7 pin harness on the motor, and what are the wires supposed to be hooked up to? I found a yamaha-only part # 688-82586-50-00 that claims to be a 7 pin main harness 16 feet long, but I have not been able to find any pictures to confirm it's the right plug, much less a wiring diagram for what i need to hook up.
Next, the kill switch on the 2004 model tiller handle has a black wire and a white wire with bullet connectors. I have no idea where these go. There's an unused ground on the motor just AFT of the starter.
Lastly, I don't see any sort of choke--is it even available with one and how do I hook it up?
So to make a long story short, I just want to figure out an easy way to be able to start this motor to at least be able to use it as a tiller for now. Any help would be GREAT! If anyone has any used parts to sell me, that would be great too!
Red
Black
Green
White
Brown
