pirates3786
Thread starter- Joined
- Jun 29, 2012
- 10
I'm replacing a factory stereo with a CD/iPod stereo.
I hooked up the leads, as the old was hooked up and followed the diagram. Instead of a red and black like the original harness, it has a red and yellow (no wire specifically for ground as I can tell), and a black with a screw terminal (for ground I'm assuming). Here's what I did:
Red to Red
Yellow to Whiteish yellow
Gray with black to green with black
White with black to red with black
White to Red with White
Gray to green with white stripe
Then I have the black with the screw terminal - I really don't know where to hook that. I hooked it on a screw terminal that I thought was a ground. When I tried the stereo, no power, no lights, nothing. So I know I need that connected correctly to get power.
Like I said all the colors were the same on the old wiring harness - the black on the old harness was connected to the whiteish yellow.
On the same console as the stereo I have a DC charger port - can I ground off of that??
Thanks for any help. I'll know next time probably not to try this.
Red to Red
