Help with removing trim unit in my 99 50hp
wilson750
I did a search and it looks liek these units are tough to get out..I am guessing i have to use some heat and a punch..Does anyone know if this is for both mounting bolts lower and upper?I took off the little pin on the top.It shot out somewhere!!!
If anyone has suggestions please let me know..
Also the used unit i got has a plug with 2 wires then it has 3 other wires 2 of them go to a mount for a ground then a white wire which is cut? What is the small part next to the trim called? What does that do? I thought the motor would move up and down if i add some power to the one side of the plug? Nope..I think the motor is shot?
wilson750
Re: Help with removing trim unit in my 99 50hp
TTT On the plug to the trim motor there is 2 wires..Are they both positive? Or is one neg and the other pos?
oldrudedude
You should post some pictures.
wilson750
Hopefully somone who has this trim unit knows if both wires on the plug for the trim are postive or if one is ground..
