Help With Ranger Boat!
Danandhannah
I have recently purchased a used 1982 ranger boat with no batteries but the wiring is all there. the model in 1600 v-3. my question is does anybody know how to hook up the wiring harnesess, on the right side of the compartment i have a hrness with a white,orange,red,black and it run to the front panel by the trolling motor. on the left i have the main black and red for the motor start and then there are also random black and red wire which go to the live well i believe. PLEASE HELP!
angler53
Re: Help With Ranger Boat!
Call Ranger and get a diagram. If they rigged the package they may still have records.
Good luck,
tashasdaddy
time to start trouble shooting with a meter.
Silvertip
Honorary Supreme Mariner
The four wires (white, orange, red, black) are for a 12/24 volt trolling motor system. You would need two batteries for 24 volt operation and just one for 12 volt operation. You could install two batteries for parallel operation to extend run time on a 12 volt motor. The trolling motor plug is very likely a three or four prong style. The panel on which the plug is mounted may have a Charge/Run switch. Here's the wiring plan for the batteries. The red and black go to Battery #1 (pos and neg respectively). Orange and white go to Battery #2 (pos and neg) respectively. If you have a 12V trolling motor, you only need one battery and it doesn't matter if you use the orange/white, or red/black pair. You can use a voltmeter to test the plug or simply remove the panel and look at the back of the plug to see which wires are on which terminals.
On the other side of the boat, red wires go to the POS battery terminal. Black wires go to the NEG terminal.
