I really appreciated the help I got on this forum several years ago when I had a water in the oil problem. Got that solved and all has been well since then. That is untill last Sunday when we went to trailer the boat and the lower unit would not come up. Boat is a 1970 Glaston V164 with a 140 Mercruiser. Had the wife help lift the lower unit and got it locked in the upper position by putting stops on the tubes. I could hear the motor running try to raise the unit. Checked it out after we got home and it appears there is a leak in one of the hoses going to the tubes. I have the hoses on order. Here is my dilema. Is there an easy way to change them out? There are 4 hoses and they go into 2 blocks in the gimble unit (not underneath it). Looks as if it may be possible to remove them but it looks to be a real pain in the you know what. Do I have to remove the lower unit from the boat to change these? I can not find any instructions on this. If anyone here could offer some help or advice it would be deeply apprciated.
Thanks,
Mark
Thanks,
Mark
