Nandy
Thread starter- Joined
- Apr 10, 2004
- 2,145
Re: Help with MTD tiller machine
ok, I miss understood your instructions. I will change that seat now. Everything you said was already done and checked. I appreciate your help greatelly. If I had understood you correct I would be done by know.... BTW, I got tecumseh book. It is great. Im supposed to set up the float at 4.3mm, I set it to 5mm to get that needle to set up with more pressure. We shall see...
When installed you should no be able to see the grove in the seat. the grove should be facing up, as in facing the top of the carb. If the grove is facing down, or out towards you it will leak like a sive.
Also to check the float the only thing you can do it look for pin holes. If any are found you can give the a quick hit with a propane torch and some solder. Also shake the float. If you have a bad float it will have fuel in it and you will be able to hear it when you give it a shake.
THe wire does not matter which side it come out on. only that it is between the float and the tab.
Make sure the needle is perfectly smooth, ANY tiny bits of gunk on the tip, or ANY pitting will cause it to leak.
Finally if all else checks out you can try to adjust the float slightly. To do this remove the float and bent that little tab slightly away from the float. This will cause slightly more pressure on the needle as the float will be sitting lower in the fuel in the bowl.
Bill
