Help with model year evinrude 55 "heavy duty"
volvoekern
MOD.No = BE55RSY
SER.No = G 02641582
This is an engine form the norwegian military so its a type of "heavy duty" 55hp. Came original with 70hp lower unit, short shaft, rope start, no power tilt/trim
jonesg
Re: Help with model year evinrude 55 "heavy duty"
Does it look like this .?:D
F_R
I see a lot of 55RSY* models, the * being another letter. Could the "G" belong with the model number? 55RSYG is a 1995
Borchik
Belgium Model, Evinrude, 55hp, rope start commercial model 22.5inch shaft. the * means its a 2 stroke and the year is undetermided because you are missing the last letters on the end. You can use this little setup to determine year...
INTRODUCES
1234567890
volvoekern
This is a picture of the sticker who sat on the shaft : Link
Borchik
look around on the powerhead, there should be a soft plug with the model/serial stamped into it also, i ran the serial on Evinrudes Dealport dealer only section and it says its not found, wondering if the one on the powerhead reads different.
volvoekern
It said G 2641582, so yes its a match!
