BudL1te
Thread starter- Joined
- Jun 8, 2012
- 63
I bought a 1972 Crestliner Mercruiser 120 - hasn't been run in 6 years, I am rebuilding the Carb, changing the oil (old oil looks fresh and clear on dipstick, has gas smell to it) Going to put a couple of squirts of transmission fluid in each cylinder and let sit overnight.
Going to clean out the fuel tank with rubbing alcohol, let it sit overnight to get any varnish out. Don't know if gas evaporated or if it was emptied after last use.
I will get new Spark plugs.
Going to change the gear oil on the out drive and Lube through grease nipples.
Here are my questions:
Is the manual for this motor posted anywhere? All the links I have clicked on in the other threads have been removed.
What oil filter does it take? PH 6 ?
Is there anything else I should do before attempting to start?
Thank you for your help.
Buddy
Buddy
