Re: help with lower unit refit 60 hp mercury
Before you install the lower unit, you need to determine which gear the lower unit is already in. The prop shaft should not turn either way in reverse. It will turn both ways in neutral. It will not turn CCW when in forward gear, but will ratchet CW.<br /><br />Once you determine which gear it is in, set your powerhead shift shaft in that position. Some people find neutral the easiest, other say it is easier in forward gear.<br /><br />Describe your problem in more detail, and we can try to help.
