Help with Live well Intakes
Revtro
I just bought a 19.5 foot 1997 Sea Nymph. I can't locate a model number. It's essentially a fish and ski with a single live well up front on the port side and a 115hp. My question is about the intakes on the back of the boat. I see there are 2 of them, on either side of the drain plug. One is black, one is white. I assume one is to take fresh water in and the other is to pump it out?? Am I correct? If so, can I plug these since I will probably never use the live well?
Ibl0wstuffup
I have a 98 GLS 195 and on mine one is the inlet for the live well and one is the drain. It won't hurt anything to plug them. I would also pull the fuse or disconnect the power to the fill pump so you don't accidentally leave it on with no water going to it.
