Help with info to redue boat
1983rinker
Here are some photos of my boat I want to redue. I was thnking abought Rhino lineing inside cost is high to to that $500.00. I can get new seats and new carpet for that. Can you guys help me to keep my cost down.
Bob_VT
Re: Help with info to redue boat
Why rhino lining? Are you going to haul firewood and building supplies in the boat :rolleyes:
Need to keep the cost down...... consider regular paint on the deck with a non slip additive mixed in........ you should to do the entire deck for under $25 with that type of top coat.
Seats ...... well seating .......... comfort cost money...... how comfortable do you want to be ? :D
You appear to be doing an interior make-over. Does the boat need anything else?
kmarine
There are other alternatives suitable if you do not like carpet like durabek or other epoxy floors. I would suggest on an older boat sealing any resin cracks with polyester resin and using carpet. this would cost under $100 and carpet will hide any floor flaws. A wire brush attached to a grinder makes easy work of removing old carpet glue. Check the internet, Many styles of boat seats can be had reasionably cheep.
JasonBo
Glidden makes a Porch PaintPolyeurathane you can get at home depot or lowes and it can be tinted to color of your choice for 22.00 a gallon.
1983rinker
Im going to have the transom redone too. I was thinking of one lounge seat on left and 2 swivel seats on driver side. Paint is a good idea with a few mats, i luv it..
1983rinker
Thanks all I will paint the floor and put down a few mats. I like it allready.
twkjr 1250
whats wrong with the transom, if soft make sure to explore into stringers as well . start near transom first good luck keep posting pics of progress
1983rinker
Na not soft, its just 27 years old. So I want to redue it.
jonesg
At 27 yrs, when you redo the transom I bet you find rot down near the bottom.
