Help With Chrysler!!!!!
JaredBlueFin
I have an older Chrysler outboard 45hp that I can't even get to turn over. I know the starter is good. I hooked it right to the battery and it turned over fine but I can't use the key or get it to start anyother way. I replaced the starter soilinoid but I don't know if I have it hooked up right or not. This is my first boat and it was free from a family member and I know it runs but it has been awhile. Any help from anybody would be great!!! Thanks!!!
ratss
Re: Help With Chrysler!!!!!
you need to find out if your start wire is getting hot if it is it should click, the big cables are usually bi
happyzee
Two things come to mind: LanLine and fuse.<br />My 150 has a fuse inside the engine. If the fuse is blown the engine will NOT CRANK. I'm not sure about the LandLine. I think it will crank if it is off, but not start.<br /><br />kz
BHM7952
I have parts catalogs and service manuals for Chrysler/Force/Sea King engines. We closed our dealership and have many parts, props and msc. available below dealer cost. Send model number and list of items needed.<br />Email: linda@nu-z.net
icwebpeople
where to find Chrysler outboard parts<br />Here are some email addresses and contacts I have found and I have bought from a lot of them. If you don’t have outlook express you may have to type the e mail address in your e mail instead of just clicking on it. I would start a the top of the list and go down that’s the order I have had the most luck with.<br />Good luck <br />discount marine weedsport n.y. ask for wayne 315-834-6843<br />www.GLM-marine.com 626-357-0077<br />nicholls marine ltd 905-871-1965<br />nicks marine 859-854-3888 let it ring a while<br />www.americanoutboard.com <br />chesapeak marine 410-286-2520<br /> http://www.bentboat.com/parts_toc_fr.html <br /> fairwinds@toad.net<br /><br /> mtech@mastertechmarine.com<br /> FranzMarine<br />linda@nu-z.net<br /> discountparts@americanoutboard.comservice@boatmotorrecyclers.com<br /><br />willyo@bellatlantic.net<br /> info@outboardexchange.com<br /><br /> info@ccomarine.com<br /><br /> sales@marineparts.com<br /><br /> DSTIBER<br />obparts2@yahoo.com<br /> Tsmyth@cfl.rr.com<br /><br />partsdesk@tenkillermarine.com<br />partsform@newagemarineparts.com<br />manualform@newagemarineparts.com<br />charlie@charliesusedparts.com<br />ironman@csweb.net<br />outboard@searnet.com<br /><br /> http://www.nicksmarineoutdoors.com/NicksMarine_Storefront/asp_StoreFront/QuickOrder_Launch.asp <br /> http://www.iboats.com/ <br /> http://www.geocities.com/thechryslercrew/ <br />you can post an add here http://www.hurrikain.com/disc1_index.htm <br />post an add here http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi <br /> http://www.marineengine.com/outboard_motors/parts/ <br /> http://www.boatowners.com/drives_vdrives.htm <br /> http://www.fairwindsmarina.com/chryslerpage.htm <br /> http://aolsearch.aol.com/dirsearch.adp?knf=1&query=chrysler outboad parts <br /> http://aolsearch.aol.com/dirsearch.adp?knf=1&query=chrysler boat parts
