help with cam throttle/tiller
larryg
i have a 1985 johnson 20 hp motor.had to put a new tiller on what is correct way to put bak together?wasnt sure if throttle control pinion and throttle control gear and shaft hv to be put on a certain way.need pictures of throttle at full position and no throttle from front of engine and from side near gears..for some reason dnt think cam throttle control and roller cam are in correct positions.hv very low idle ,when i adjust idle to run ok ,put in gear i cannot back the throttle down..have looked in omc manuals and cant find anything.thanks very much for any help
