Help with 94 CobraSX parts
finsterx8
Why is it so hard to get listings on parts? I took my out drive off to replace the Gimball and don't believe there was a paper gasket between the housing. The gasket set it calls for does not fit around shifter cable and nothing else in any online catalogue. Should there be a gasket on this model? And what about the shifter cable boot? The one in the catalogue is way too big.
Lastly where can I get an OE manual?
(I'm trying to resize pictures to upload)
finsterx8
The gasket goes right where the shifter cable comes through
vasy
finsterx8
Thanks I will look into those. No image available on the cable and Volvo site won't let me on because I'm in Canada.
vasy
Ha, too funny. I'm also in Canada so can't use that site as well :)
Search that part number on ebay or google, you will see the whole part . It is complete cable with the boots on it already.
Check your local Volvo Dealer, I' not sure which province you are in, Vancouver I stop by local guy at times.
I 'm not sure you really need those boots as they are not there very tight and I'm sure they let water in. They are probably more for looks.
I called local dealer, was told that it is only sold OEM with new cables only.
