runninfarmer
- Jun 28, 2012
- 142
HI everybody. I just finished rebuilding my water pump in a 1987 88 SPL Johnson, model J88MSLCUS. I got the motor running after it sat for 8-10 years. It actually was idling pretty good. I was happy until I noticed water leaking out of the exhaust cover. I sprayed fogging oil through the carbs to protect bearings, etc from any potetnial water and shut the motor off. I pulled the exhaust cover and have ordered new gaskets. I have a few questions though, since my service manual doesn't cover the procedure for replacing the gaskets and putting the cover back on. Also doesn't have the torque specs or bolt tightening sequence. I'm assuming it's a spiral pattern? I've attached pics of the cover and inside the exhaust side of the engine. There is a lot of carbon in there and on the cover! Should I use Permatex gasket remover to clean the carbon and gasket residue?
I've used this thread for reference:
http://forums.iboats.com/johnson-ev...-exhaust-cover-gasket-replacement-333096.html
In that thread someone mentioned " Exhaust Housing to Powerhead screws (V4) 16 - 18 ft. lbs . Use OMC Gel Seal II as sealant. Exhaust Cover screws, 60-84 in. lbs., use OMC gasket sealing compound. I have J90TLCUR also."
Which are the exhaust powerhead screws and which are the cover screws? Thanks for the help!
