- Apr 17, 2002
- 71,535
Re: help with 82 5.7 to vortec upgrade, flywheel question
Ayuh,... Of course the coupler works,...
The Outdrive's Input Driveshaft is what I'm talkin' 'bout....
You said yer's has the short shaft, 'n I'm sayin' that's the Wrong shaft, for that application...
It'll Run, but not for long...
It's only utilizing 1/2 of the available spline length...
Bondo,
The Sierra the part I recommended (above) is in their catalog described as:
"18-2172 Engine coupler: Used when replacing V6 or V8 engine with 2pc rear main seal with 3-1/2” crankshaft bolt pattern to a newer 1 pc rear main seal engine with a 3” bolt pattern."
Since the description matched what I (and Capitan828) are trying to do I bought it. Upon arrival I have verified that it fits my new crankshaft and is otherwise dimensionally identical to my old coupler so it mates with my R drive perfectly.
It works as advertised, I don't know what else to tell you.
Steve
