TwoBallScrewBall_Alt
Thread starter- Joined
- Jul 9, 2019
- 19
1988 OMC 5.0 Carb, with the Log style rear-riser manifolds. Had a noisy lifter, pulled the starboard valve cover and found the rocker loose, tightened it up to spec.
I've been fighting for an hour to coax the rear outer bolt and spreader plate back into place. There is not even room for a finger between the valve cover and the starboard riser. I was able to remove it with a 1/4" universal and some cursing, but I can not get it back in.
Any tricks to getting this bolt back in place before I pull the starboard riser? I would much rather not disturb the exhaust. But I am not seeing another option.
Thanks.
Thanks.
