help with 1991 force 70 hp outboard
hamiltoc
the motor ran fine all day sat. and died on me at the end of the day. I can not get the motor to run unless i take out the top 2 spark plugs. it will run on the bottom plug by itself. as soon as i put the other one or two plugs in it. the motor will not fire. I am getting spark to all the cylinders. the spark plugs are brand new. any help would be greatly appreciated.
roscoe
Re: help with 1991 force 70 hp outboard
You need to do a compression test.
You can get a tester at any auto supply store.
