The motor runs fine upto quarter throttle but then does not accellerrate. I checked high speed jets they are ok. Fuel is always in glass bowl. Any help is appreciated
So what happens above 1/4 throttle? Continue to run, but slow? Quit running? Misfire and jump around?
Not knowing the answers to those, I say to check to see if it is running on all 4 cylinders. My guess is it is running on two.
Hey thank you I have no continuity on cyl 3 wire. Before I posted this I cleaned up points on the distributor and took it for a spin only have marks on cyl 1 & 2. Cyl 4 wire has continuity but no mark on the point.
