HELP, What is this wiire on my Faria multi-function tach?
pvett
I have a Larson Senza 206. I have a Faria Multi-function Tachometer. My tach is not working. When I turn the ignition switch, it doesn't jump, so I assume it's not getting power. The picture is of a wire that is attached to the power terminal. Already attached to the power terminal is a purple wire (power) so I'm not sure what this wire does. Right now this wire is not attached to anything else but the tach. I assume this is my problem. Does anyone know what this should plug into?
thanks,
Phil
Bill kubiak
Re: HELP, What is this wiire on my Faria multi-function tach?
I just installed a new faria tach in my boat. I cannot tell you anything from that picture
Purple wire to pwr
Black wire to ground
Grey wire to signal
pvett
yea, i'm not sure what the second wire is for? It comes off of the terminal red, goes into this red plastic fuse box looking thingy, then a wire comes off of that black and goes into nothing... Anyone else have any ideas?
