Hello:
Just before Father's day, I purchased a 1978 Tom-boy S5W (14ft). It has appeared to be a little on the heavy side, but I just assumed that it was old heavy fiberglass. The last time I launched it it was really sitting low on the starboard (right) aft (rear). It appears that the foam is waterlogged. The floor is fiberglass. (Who knows what is underneath it!?!) It appears that the floor is inserted in the outer hull as a liner. I suspect that the leak into the interior of the boat is under the driver's seat. (drivers seat base is fiberglass and part of current floor. Small hole under seat base appears to go into the bottom of the boat.) The area under the seat is questionable at best. This area appears to be wood with a little thin epoxy over it. The area where I place my feet as a driver is a little soft. I had considered trying to pull the whole floor piece, but the transom appears to be solid. So I am thinking about replacing the floor up to the rear of the fish well. Alternatively, I could either leave the fishwell attached to the port side of the hull or cut it out and then re-glass it in after I am done.
My plan is to pull cut the fiberglass floor out. Then I will remove any wet foam. Next I will put a partial sheet of marine plywood in and glass the cut-out section back in place. One issue is that the original owner had pulled out the carpet and painted the floor. How can I get the glass to bond to this? Any comments?
Terry
Terry
