Silvertip
Honorary Supreme Mariner
Thread starter- Joined
- Sep 22, 2003
- 28,772
There are three posts in a row where the question was asked "what prop is best for me?" I don't know about everyone but my response is "pick one -- your guess is as good as mine!" How about giving us something to work with! Remember, we can't see your boat, we can't see your engine (year, HP and model #), we don't know what prop you have now, we don't know what your current maximum speed is, or what the recommended maximum rpm is for your engine (because we can't see it). Furthermore, without a tachometer and speedometer and some actual wide open throttle rpm and speed readings with what you consider an average load, ain't no way short of a lucky guess we can help you unless someone has exactly the same boat, same engine, same load, and same prop. Lastly, it helps to know what performance issue you want to fix. Simply saying I want more speed so should I buy a 21P? Putting that prop on an engine that currently has 19P very likely will slow you down rather than speed you up because the engine does not have enough power to turn that much pitch. I suggest you google "propeller theory" or "selecting a propeller" so you understand how a prop works and what you need to know in order to make an informed decision. Without the required information we keep answering the same old questions over and over again and quite frankly, "it gets old". There -- I feel better now but I still have a headache! :|
