Any advise here. I had to replace my Lower unit on my boat. I brought a used one and had to have the shaft cut by 1/2". I had the machine do it professional. After I replaced I took it to the lake and it was slow to start ( boat had sat up 4 months) but finally it cranked. I ran it for about 30 minutes stopping and going. It was slow coming out of the hole like it was starving for fuel. Took it home and decide to add sea foam tot he gas and topped it off with fuel. I charged the battery all night and got to the lake the next morning and it cranked fine. Stopped and fished for 30 minutes then it would not crank again, sounded like a dead battery. Tried to jump it from trolling motor battery and it would not budge. All it would do is click. I buy new battery and same thing happens. So I figured it was the started hung. Take off all the covers ( under side of cover had plastic shavings in it) and noticed that the starter was indeed struck in up position. I lowered the starter and I could not turn the flywheel , I removed all the spark plugs and still could not do it by hand. I can turn the prop in neutral but cant budge it in forward or revers. Tonight I'm going to remove the lower unit and see what happens next. any other suggestions on what I might try?
