HELP!! Trim Question
24ANGLER
I just came back from the sandbar. I have a 2005 Merc 250 EFI Saltwater. I noticed the pin that holds the ram cylinder in place is 3/4 out and bent, Its just hanging on... How would one attack this problem? Can I purchase just the pin and re-install it? Any advice would be greatly appreciated....
I would post the picture but not sure how
Thanks
The_Kid
Re: HELP!! Trim Question
Yes. you can buy just the upper pivot pin. You also need a new tri-lobe pin to hold the new pivot in place.
24ANGLER
Awesome! thanks for your reply.. I have worked on alot of mercs but wasnt sure about this one.. So the Tri-lobe pin would be the knuckle if you will on top of the ram? Is there a sleeve in there as well?
Thanks
