HELP!! trigger part number 96452A 4
wayne72472
i have a 86 classic 50 45horse i put a new trigger on it today because the white wire with the black stripe on it had rotted and turned green. got the new one on and saw the old one had the white/blk stripe, brown, white, and purple. the new one had a black wire not a white/blk stripe wire. do i put the black wire there or do i need to send it back???
the purple and brown are no brainers but the other two i am not sure of
new part number is 96452A 4
Laddies
Banned
Re: trigger
Re: trigger
It is probably the same trigger with a different wire color, however not knowing the manufacture or the part number I would suggest checking at the point of purchase
wayne72472
Re: trigger
Re: trigger
the part num. for the new part is 96452A 4 made by quicksilver
Laddies
Banned
Re: HELP!! trigger part number 96452A 4
That is the proper number for your engine if it was in a unopened box or has the number stamped on it use it by simply swaping the colors
wayne72472
so i put the black wire where the white and black stripe wire was?
thanks for your help
