Petedacook
- Jul 20, 2015
- 44
Well, I changed the heat sensor and it stopped sounding off at low RPM. I also adjusted oil ratio and ran it 40:1 instead of 50:1. With the 40:1 mixture I ran it hard full throttle for a couple hours. After a the couple hours full throttle, the heat sensor started going off.
I am not sure if the overheating is related to the oil ratio, but I am going back to 50:1 ratio. I am going out this weekend and will see how it does.
The reason I changed the oil ratio was because the book says to run 50:1 only if using Tohatsu oil, and use 20:1 if any oil other than Tohatsu is used.
